Group: DynoMotion Message: 10278 From: cyfer_luis Date: 10/9/2014
Subject: problem with mach3-kflop and y axis
Hi all,
during long and hard kflop setting, i found a new problem.
when move the y axis (only with y axis), the button reset begin flashing and display "emergency mode active".
the problem occurs whit the kflop connected but it is with the electronics on or off.
i'd change various settings motor (speed, acceleration, ecc...) and pin connection but the same problem.
someone help me.
Saluti
Cyfer
Group: DynoMotion Message: 10294 From: Tom Kerekes Date: 10/9/2014
Subject: Re: problem with mach3-kflop and y axis
Mach3 doesn't allow you to disable the EStop input.  If it is configured as a Y axis Step Pin then when the Y axis is moved there is a chance that the Step Pin may be sampled when it is active and trigger an EStop.  Check your Mach3 | Config | Ports&Pins | Inputs | EStop.  If you dont have a valid EStop Input wired then configure it to an unused signal like Port0 Pin0
Group: DynoMotion Message: 10299 From: cyfer_luis Date: 10/9/2014
thanks, it works again.
this group is really helpful.
Saluti
Cyfer
